Removes secondary IP addresses on a VLAN that were added to support multinetting.
| vlan_name | Specifies a VLAN name. |
| vlan_id | Specifies a VLAN ID. |
| ip_address | Specifies an IP address. |
| all | Specifies deleting all existing secondary and anycast IP addresses. |
N/A.
After you have added a secondary IP address to a VLAN (configure [ {vlan} vlan_name | vlan vlan_id]add secondary-ipaddress anycast [ip_address {netmask} | ipNetmask] ), you cannot unconfigure the primary IP address of that VLAN until you delete all of the secondary addresses. Use the all keyword to delete all the secondary and anycast IP addresses from a VLAN.
The following example removes the 10.1.1.0 secondary IP address from the VLAN "multi":
# configure vlan multi delete secondary-ipaddress 10.1.1.1
This command was first available in ExtremeXOS 11.0.
The vlan_id variable is first available in ExtremeXOS 16.1.
The capability to delete anycast IP addresses was added in ExtremeXOS 30.7.
